would a 5 spd out of a 91 firebird fit my......
Old May 3, 2001 | 09:41 PM
Slow83Z28Camaro's Avatar
my dad found me a 5 spd trans out of a 91 firebird for 550 bux, i got 30 days on it, would it fit my 83 z?i have a 700r4 in rite now, would the swap be easy or would be hard and wouldit fit?i have a 305 motor,whould i need a diff driveshaft?would the swap be possible? thanx for the help if any 1 replys
Old May 4, 2001 | 10:31 AM
any 1?
Old May 4, 2001 | 10:40 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Driveshaft is the same for a T-5 and a 700.
The trans will work if it's a V8 one, except the flywheel won't bolt to your crank. You need a 86-back flywheel for the 2-piece-rear-main-seal system, but the 91 will be for the one-piece.
"Easy" and "hard" are relative terms. Some people would get it done in an afternoon and drive the car the same night, others.... might have more trouble. Judging by the type of questions you're asking, I'd guess you're more likely to be one of the latter. But it's certainly possible to do it.
You'll need the pedals including the bracket they mount in, and the clutch hydraulics; you'll have to install the holes in the firewall for the master cylinder.
ICON Motorsports
Old May 4, 2001 | 11:54 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Please see the transmission section of the FAQ on this website. It tells you what you need and how to put a manual trans into an automatic car.
West Coast GM Shootout 2001!
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.23 @ 107.62 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
Old May 7, 2001 | 06:21 PM
thanx guys
Old May 7, 2001 | 07:03 PM
OLDYELLR's Avatar
Car: '85 IROC
It will fit if the Firebird was also a V8, but not a V6.
1985 Yellow IROC-Z 5.0 HO, T-5 3.73 Torsen, 4 wheel disks
PFCM pads, GTA wheels, Koni yellows, B&M Ripper, Dynomax
Old May 8, 2001 | 11:54 PM
i think the v6 trans fit the v8s also, 1 guy was tryin to sell a iroc with a v6 5 spd hooked up to a 305
mikey8494
Aug 22, 2015 07:57 PM
Spd-Kilz
Interior Parts Wanted
Aug 15, 2015 12:12 PM
transam84
Exterior Parts for Sale
Aug 14, 2015 08:54 PM
Dquickshift
Aug 12, 2015 06:21 PM
armybyrd
Aug 10, 2015 09:23 PM
