How do I change rear end fluid, PLEASE HELP IMMEDIATLY
Old May 19, 2001 | 03:51 PM
GTAlover's Avatar
Car: 1986 Camaro
Axle/Gears: 4.10
Do I take off the whole cover? Do I need a gasket? Thanks
Old May 19, 2001 | 04:02 PM
bbtaz97's Avatar
Car: 91 RS
Engine: 350tpi comming soon!
Transmission: fixed the 700r4 again!
unless you have a rear dif cover with a drain plus you have to remove the rear dif cover. yes if you remove the rear dif cover you will need a new gasket
91 camaro RS
- 305 TBI
Mods: Performer TBI intake, 1" TBI spacer, K+N, jet fan switch ,160 thermo,Accel control module, Jet Stage 2 chip, edelbrock TES headers, Compleate 3" Flowmaster exhaust, Edelbrock springs, KYB struts and shocks, 700R4 built by TSI, SLP tq converter, b+m trans cooler, white guage faces, megashifter..
next month: spohn LCA's and panhard rod, BMR relocation brackets, 323 gear
Old May 19, 2001 | 06:17 PM
87rustybluebird's Avatar
i dont even use a gasket whan i put the diff cover back on, i just use silicone and trim it after its cured.
Old May 20, 2001 | 06:28 AM
bhaas's Avatar
I was gonna ask this same question. I don't have the drain plug on mine. Draining it doesn't seem to be a problem, but how do I get oil back in it??????
Old May 20, 2001 | 06:41 AM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
I've never seen a rear diff with a drain. As far as filling it back up, there's a small plug on either the upper right or upper left side of the diff. It should be a square 3/8" or 1/2" drive "pipe plug" thing. Remove it. (Just make sure you lube it up with plenty of penetrating oil and let it set for a while or you'll pull a groin trying to get it off.) Pour the oil in until it reaches the level of the hole. Also, check a manual so you use the proper lube. Reinstall the plug and you're on your way.
hectre13
Dec 11, 2023 08:14 AM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
BlackBoulder
Aug 11, 2015 11:15 PM
