help! severe wheel hop
I took my car to the strip last night and the rear axle was bouncing so badly it rattled my brake light switch right out from under the dash. has anyone had the same problem or any ideas how to fix. car is a 87 firebird, 350 crate engine, 5 speed, 3.27 posi, 275/50/r15's on the rear, stock susp.
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Steve Spohn torque arm, lower control arms with relocation brackets and panhard bar will fix that. Don't expect to be able to hook up with stock suspension. It's designed to a comfort ride not performance.
Follow my racing progress on Stephen's racing page
and check out the race car
87 IROC-Z SuperPro ET Bracket Race Car
461 naturally aspirated Big Block
Best ET on a time slip: 11.242 altitude corrected to 10.69
Best MPH on a time slip: 121.52 altitude corrected to 127.76
Altitude corrected rear wheel HP based on power to weight ratio: 504.5
Best 60 foot: 1.546
Racing at 3500 feet elevation but most race days it's over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car, 91 454SS daily driver, 95 Homebuilt Harley
Best 60 foot: 1.546
i just finished going through the #ss end of my car and found one broken shock (internal) and a tranny mount that was pretty much ripped in half. does anybody know where to get a set of LCA relocation brackets?
Car: 89 Formula / 09 G8
Engine: LS1 / LS3
Transmission: M6 / M6
Axle/Gears: 3:42 / 3:27
Steve Spohn sells then allong with BBM (BMM?) I had the same problem so i replaced the shocks. STILL had wheel hop, so i bought new LCA's... they fixed the problem. I then bought SFC's and they tightened up the whole car. Try shocks first, especially since they help handling as well, then do the LCA's you should be all set after that.
Hotrodboba400
Dec 10, 2019 07:07 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
