2.73 to 3.42?
Old Feb 14, 2009 | 11:04 PM
caseworker2's Avatar
2.73 to 3.42?
I have a 91 Firebird Formula Automatic with stock 305 and TBI. I was just wondering what the advantages/disadvantages would be if i swapped the stock 2.73 rear end for a 3.42? A buddy of mine has an 85 camaro with the v6 and i was considering getting the rear end from him.
thanks
Old Feb 14, 2009 | 11:14 PM
Darkshot's Avatar
Car: 91 RS
Engine: 350 TBI
Transmission: WC T5
Axle/Gears: 3.42 Posi
Re: 2.73 to 3.42?
You will notice an increase in acceleration as long as you can keep traction, however without a posi there's no telling what will happen off the line. There's a chance you will notice a decrease in highway mileage, but it will probably be negligible.
As far as I know that rear end will be a direct swap. You are still going to have an open rear end and drum brakes. I would say it's only worth the work if you are getting the whole axle for free, or less than $50.
Keep in mind the 85 has 26 spline axles as oppose to the 91 having 28 spline. All this means is the 85 axle is slightly weaker, but with a stock 305 there is nothing to worry about. Just keep this in mind if you ever upgrade your engine significantly.
If it were me, I would save up another couple hundred or so and look for an axle out of a 98-02 Camaro. It's a *almost* a direct swap, but that way you can get 3.42 gears with a posi, as well as disk brakes, all in one package. It will probably run you at least a couple hundred however and it will be 2" wider each side so stock wheels will be pushed out that much.
Old Feb 15, 2009 | 01:02 AM
Re: 2.73 to 3.42?
what would i have to do to get the 4th gen rear end to hook up?
Old Feb 15, 2009 | 10:44 AM
vorticaldavid's Avatar
Car: 1992 Camaro RS Convertible
Axle/Gears: LS1 posi/disk 3.42
Re: 2.73 to 3.42?
from my understanding, the e-brake cable will have to be modified to hook up and if u get a 4-channel rear (traction control?) u will have to install a t-fitting for the brakes to work, or just look for a 3-channel rear since it should have that t-fitting on it already. oh and a new proportioning valve for a disk/disk car is also highly recomended. a search should get you more/better answers
Old Feb 15, 2009 | 11:16 AM
Darkshot's Avatar
Car: 91 RS
Engine: 350 TBI
Transmission: WC T5
Re: 2.73 to 3.42?
A 4 channel rear end or a 3 channel rear end will both work fine. 4 channel rear ends = traction control, 3 channel = no traction control. I put a 4 channel on mine, you leave one of the hardlines on the rear, then take your T-block and the other hard line from the 3rd gen drum rear. Search for posts made by me under Search > Advanced Search with keywords "4th gen rear installed".
What he said about he ebrake cable ^^^^ this is the hard part, since there is no direct-fit cable. You will have to come up with your own solution.
dbrochard
Jan 28, 2016 08:42 AM
JSDaddy189
Sep 26, 2015 03:50 PM
64Chief
Sep 12, 2015 08:05 AM
john204481
Sep 7, 2015 03:22 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
