Speedo Questions
Old Feb 15, 2009 | 12:00 PM
rads84n94camaro's Avatar
Car: 94 Camaro RS. 84 Z28 350 T5
Engine: V6 & V8
Transmission: Automatic & Manual
Speedo Questions
Im not too sure where to post this so i figured this would make the most sense to post it here. I have an 84 z28 that i converted over to a 350 and instead of keeping the 700 r4 i replace it with a t5 transmission. does anyone know how to get the speedo hooked back up or wut i need to do. and also how about the neutral safety switch from what i have read all it is are to wires underneath the dash that i need to splice out with the ones that went to the automatic. a yellow and purple wire? some help would be much appreciated. thanks alot
aj
Old Feb 15, 2009 | 02:08 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: Speedo Questions
You have a cable-driven speedo, right? You need a vehicle speed sensor (VSS) from a cable driven T5 transmission. The one from the 700R4 will not fit in the T5.
Did you read the tech article on swapping from an automatic to a stick shift?
Old Feb 16, 2009 | 02:35 PM
Engine: V6 & V8
thanx ya ill have to look it up ive bin so damn busy workin two jobs n skool i havent even touched the car in awhile
Eric2ndGen
Nov 5, 2015 01:51 PM
stickychinsac
Aug 31, 2015 06:06 AM
IROCZDAVE (88-L98)
Aug 24, 2015 06:54 AM
redmaroz
Aug 16, 2015 11:40 PM
beachrodder
Aug 7, 2015 04:27 PM
