Spedo gear question on a T5 with 3.42 rear
Old May 22, 2001 | 02:00 PM
Rylos's Avatar
swapped in a different T5 on the TA !
problem the speedometer is over by 14 mph
or 22 km the differential ratio in 3.42
I have my original diff (just rebuilt)
3.73 posi.
if i swap in the 3.73 will it correct my
speedometer??? If not what gear(S) do i need!
thank in advance
Old May 23, 2001 | 06:09 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
3.42 gears for a T5 take a 7 tooth drive gear and a 19 tooth driven gear. The problem is to change the drive gear you have to remove the trans...
The 7 tooth is blue and the 19 tooth is white. The other choice for a drive gear is a 9 tooth, and its red.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.23 @ 107.62 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
loud91rs
Oct 5, 2015 10:05 PM
Numbah-1
Oct 2, 2015 08:27 AM
Galaxie500XL
Oct 1, 2015 01:05 PM
JSDaddy189
Sep 26, 2015 03:50 PM
