best bolt in rear end?
Old Feb 17, 2009 | 11:14 AM
r-borgmi's Avatar
what would be the best bolt in replacement rear end for my 86 camaro ?
just looking for the best thing i can buy used and install 4.11 gears into
prefer disc brakes. and what cars do i look for that had it. thanks
Old Feb 17, 2009 | 11:56 AM
big gear head's Avatar
Re: best bolt in rear end?
The best would be a Moser 12 bolt. You won't find one in a salvage yard. About $2200 new. Next best would be the Dana 44. Probably won't find one of them in a salvage yard either. Next would be the 9 bolt Borg Warner. Lots of them around. You will have to get one with a 3.27 gear if you want to install a 4.11. Most of them had disc brakes. Next would be the '90 and later 10 bolt. These had larger 28 spline axles than the earlier 26 spline axles. You can get a new Eaton posi to go with the 4.10 geare and it will probably hold up pretty well if you don't use too much power and traction. All of these are going to be Camaro or Firebird rear ends. No other rear ends will fit these cars.
Old Feb 19, 2009 | 03:24 PM
l_dis_travlr's Avatar
Car: 90 Formula -- tot resto in progress
Transmission: 700R4 w/ 2500 stall, by Owen @ ARD
Axle/Gears: 3.23 posi disc
b-g-h, check your PM...
kk
hectre13
Dec 11, 2023 08:14 AM
sailtexas186548
Jan 19, 2016 12:21 PM
hectre13
Aug 26, 2015 08:17 AM
Jlanz55
Aug 17, 2015 07:15 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
