After Rebuilt Tranny??
Subscribe
May 24, 2001 | 06:33 AM
I just had my tranny rebuilt w/ a manual valve body. It shifts fine and now I have OD. But for someone reason maybe it is me, it just doesn't seem to pull as hard as it used to. Could this be in my head or I was thinking maybe the TV was adjusted wrong and can't get WOT.
Another note, I thought when you have a manual valve body if kept in Drive the car shifts automatic which it does for me except if I drive along in 3rd and go to WOT, the tranny won't kick down to 2nd, could this all be related to the TV and WOT adjustment?
'86 IROC
T-TOPS, TINTED WINDOWS, BRAKE LIGHT BLACKOUTS
GM GOODWRENCH 350
EDELBROCK TES HEADERS
FLOWMASTER
EDELBROCK 600CFM CARB.
KN AIRFILTER
ACCEL HEI DISTRIBUTOR
2:73 GEARS
Rebuilt 700R4, with manual valve body
Soon to be installed B&M Megashifter
and Exhaust Cut-Out
Reply 0
May 24, 2001 | 04:59 PM
With a full manual valve body you would have to do all upshifts and downshifts with the stick wouldn't you?
Reply 0
May 24, 2001 | 08:36 PM
Can somebody explain this to me, if the 700R4 can be switched manually easily (with a B&M) what are the advanteges of t5's over the auto's ? (except that manual has 5 speeds)
-Max
Reply 0
May 24, 2001 | 10:28 PM
Yes, with a full manual valve body you would have to do upshifts, but I don't have a full manual at least that I know of, because if I keep it in drive it will shift through all the gears.
I checked the TV cable and throttle today and the throttle opens all the way.
'86 IROC
GM GOODWRENCH 350
FLOWMASTER
KN AIRFILTER
2:73 GEARS
and Exhaust Cut-Out
Reply 0
Subscribe
