What year camaro is this rear end out of?
Old Feb 18, 2009 | 05:36 PM
GMODUDE's Avatar
Car: 92 Camaro RS
Engine: 5.7L 385 Fastburn
Axle/Gears: 9 Bolt 3.70 Gears
I just bought a 9 bolt rear end and was told it was out of an iroc. I ordered some calipers off of a 90 iroc and the bolt holes on the caliper are 4 inches apart while the mounting plate on the rear is 5inches apart. I checked the rear for numbers and i have these casting numbers.0578026901 6 731. if someone could give me auyear or something this rear came out of ide appreciate it. or any knowledge about the subject would help.
Old Feb 18, 2009 | 05:39 PM
I H8 WWD's Avatar
Car: 89' IROC-Z
Engine: LO3
Axle/Gears: 10-Bolt/2.73
Re: What year camaro is this rear end out of?
I think that might be the Borg Warner 9 bolt.
Straight from Camaro Tech Data (My new friend)
"All TPI 350 (1987-1992) Camaros had a tach with yellow at 5000 and red at 5500. They also all came with the Borg Warner 9 Bolt and 3.27's in 87 only, other years it was optional."
Can be found in 86's as well (But its reported there were only 50 of these and they were test cars).
Old Feb 18, 2009 | 05:45 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
My "guess" is that you have a 9-bolt with Delco-Moraine single-piston iron calipers and 10.5" rotors. A 90, however, with disc brakes would have been equipped with single-piston alum calipers (PBR's) and 11.7" rotors.
JamesC
Old Feb 18, 2009 | 10:31 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
9 bolts were available from (Pontiac started in 86, Camaro started in 87) to 89. The 89 models got the PBR brakes. By 1990, the 9 bolt wasn't offered any more and the f-body just got the 10 bolt.
Old Feb 19, 2009 | 09:57 AM
I H8 WWD's Avatar
Car: 89' IROC-Z
Engine: LO3
We need to update the camaro tech data then if the above is true, as it states (and I did above right from CTD) that it was optional THROUGH 92'.
Please verify. We dont need wrong informational data on TGO.
Old Feb 19, 2009 | 06:34 PM
GMODUDE's Avatar
Car: 92 Camaro RS
The rear i have has no brakes on it at all, thats why i am asking to start with. Im pretty sure it was optional through 92 to get a 9bolt.I was told it was a borg warner. It must be out of an 87. because i orderd some calipers for a 90 iroc with performance package and the caliper bolts didnt line up. I orderd some calipers today off an 87 *fingers crossed* hope this works
Old Feb 19, 2009 | 06:43 PM
AlkyIROC's Avatar
Car: 87 IROC L98
The 9 bolt may have been optional up to 92 as an over the counter option but it wasn't offered on a production vehicle as an option after the 1989 model year.
hectre13
Dec 11, 2023 08:14 AM
AkDrifted
Aug 17, 2015 07:45 PM
mizz0313
Aug 12, 2015 06:45 AM
BlackBoulder
Aug 11, 2015 11:15 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
