Do I need to change my flywheel to swich to a T56
Old May 24, 2001 | 10:54 PM
84 Z-28 350's Avatar
Car: 84 Z-28 Camaro, 2022 2500 silverado
Engine: 383
Axle/Gears: richmond 3.73, eaton posi
I have a 84 Z-28 that I converted from a LG4 305 auto to a 355(350 .030 over) and a borg-warner T-5. I am looking to upgrade to a T-56, but all the tech articals say I need to swich the flywheels, wich would be inpossable because I have the old style 2-pice rear main seal wich uses a neutral ballanced flywheel and the new 1-pice rear main (86&up) use a counterweighted flywheel. Any suggestions.
Old May 25, 2001 | 06:01 AM
Brian Shaughnessy's Avatar
Car: '89 Formula
Engine: 355 TPI
Axle/Gears: 3.70 9 bolt.
If you're gonna use a used tranny out of an LT1 car, yes. The gearset for most of the 94-97 cars has a 2.66 1st gear and a .50 OD.
Otherwise here's a tranny that works. Same gearset as the '93 LT1 tranny (2.97 1st, .62 OD). It's drilled for a T-5 bellhousing.
http://www.salleechevrolet.com/BorgWarner/bwt56.html
Note: Scoggins Dickey sells it for much less.
http://www.sdpc2000.com/cart.asp?act...d=684&pid=1172
This was just a better description.
'89 Formula - Thunderchicken - 355 Vette L98/T-5/3.45 9-bolt/black/t-tops - the fun car!
'90 GTA - The GTA - 5.0 LB9/TH700/3.27 9-bolt/black/t-tops/tan leather - the cruiser.
[This message has been edited by Brian Shaughnessy (edited May 25, 2001).]
Old May 25, 2001 | 08:39 AM
3RDGENFRANK's Avatar
Car: 1992 Camaro Z28
Engine: 406
Axle/Gears: 4.10 GM 7.5 10-bolt
McLoed and Centerforce make flywheels for a two-piece rear main seal engine and a T56. They run between $250-$300. You will also need a T56 specific clutch. Check out SLP, Star, or Centerforce.
1992 Camaro Z28; Engine:383 w/Ported Edelbrock RPM heads. Lunati Solid Roller Cam 224/232 .502/.502, Fluidampr, Comp Cams 1.5 Roller rockers and lifters, Comp Cams Triple Valvesprings, SVO 30 lb injectors. Holley/Walbro 255 lph in-tank pump, Haltech E6GM DFI, SLP 1 3/4" headers, 4" Mufflex, T56, SLP Clutch, Pro-5.0 Shifter, 4.10 Gear, Auburn Offroad Pro Posi. Super Ram. 17" X 9.5" Ronal FireHawk Rims w/ 275 40ZR17 Bridgestone RE 730's up front and Nitto Drag NT 555R's out back.
Double-Pump This! EFI Rules!
Old May 25, 2001 | 03:31 PM
ScreaminDeamin85Z's Avatar
do a search under my username in the last 6 months and you will find ll the info you will need concerning the flywheel.
Brandon
"ScreaminDeamin 360"
350 60 over, TRW forged 9.83:1 pistons,Hooker Comp headers, crane cam 216/228 .484/.512, crane 1.6 RR's, ported plenum, home made ram air, 24lb SVO injectors, crane AFPR, all going through 3 inch mandrel pipe and a flowmaster.
New project-89 IROC-Jamex Springs...and thats just about it till summer!
Soon- 6 speed, Pro 5.0 shifter and 4.10's
http://users.argolink.net/bvana
http://ScreaminDeamin.cz28.com
Old May 26, 2001 | 02:42 PM
camaro1j's Avatar
Car: 92 Camaro
Engine: 406 sbc
Axle/Gears: 9" ME with 4.56 gears
If you are going to put alot of HP buy a bob wier bellhousing and hydrolic throw out bearing.Then you can use what ever flywheel you want.You can also get rid of that crappy clutch set up that comes with the T56.
www.geocities.com/camaro1j/myz28.html
406
accel supper ram
6000 rpm Hyd roller cam
afr heads
spohn torque arm and crossmember
t-56 trans, [wier racing bellhousing and hydrolic throwout bearing]
9" ME rearend 3.91 Gears
BlackphantomZ28
LSX and LTX Parts
Oct 19, 2015 06:25 PM
19irocz85
Aug 31, 2015 10:31 PM
BlackphantomZ28
Aug 31, 2015 10:29 AM
Trickskier
Aug 29, 2015 01:12 PM
sreZ28
Aug 14, 2015 07:48 PM
