Help With Speedo Housing
Old Feb 22, 2009 | 12:34 AM
Sooo_slow's Avatar
Car: 82 Z28
Engine: 327
Transmission: TH350
Car has a TH350, and the car needed a speedo cable, went to throw it on and ...
I've never seen a housing like this. Usually its a simple one sleeve screw on type.
And there isn't enough room to get the cable screwed on.
What do I need to replace?
Picture should be rotated, but you get the idea, housing faces inner drivers-side tunnel.
Old Feb 22, 2009 | 06:19 AM
DeanJ's Avatar
Car: 1988 Camaro, 1986 S10, 2000 Harley
Engine: LS6
Axle/Gears: 3.75 9" ford trac loc
Re: Help With Speedo Housing
Hi, Thats a ratio adapter. Unscrew the big nut and the regular cable hookup will be there. Dean
Old Feb 22, 2009 | 06:53 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
However, if you eliminate the adapter, your speedo will probably read incorrectly. Apparently a former owner used the adapter instead of replacing the drive and/or driven gears.
JamesC
Old Feb 22, 2009 | 07:59 AM
Sooo_slow's Avatar
Car: 82 Z28
Engine: 327
Transmission: TH350
Perfect, thanks for the info.
It may have the adapter, but there's no way you could actually get a cable onto it, so it's useless on my car I believe.
I'll just pull it off, throw the cable on and get some sort of baseline.
Thanks for the help guys.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
rs_z28_vert
Sep 30, 2015 09:47 PM
