Bought a used set of 3:42 , is there a quick way to confirm the ratio
Old May 31, 2001 | 05:56 PM
Blue91''s Avatar
I just got a used set of 3:42 rear gears and I just wanted to make sure they are actually 3:42 before I install them. They are GM gears and the only identification numbers on them are ( 12:41 GM 7 5/8 ) . Is there a quick way to confirm that they are actually 3:42? I dont have any other sets of gears to compare them to.Is there is a measurement or tooth count I can do? Any help would be great . thanks
Old May 31, 2001 | 06:09 PM
transfixleo's Avatar
Yes, divide the number of teeth on the Ring Gear by the number on the Pinion.
Old May 31, 2001 | 07:00 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
41 divided by 12 = 3.416666666666667.
Sounds like 3.42's to me.
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R4. 2.93 limited slip. Cat-back from '91 GTA, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LG4 w/'87 LB9 block, ZZ3 cam and intake, World 305 heads, Hooker headers & y-pipe, 3" Catco cat & 3" cat-back).
57 Bel Air, my 1st car. 0.030 over 396, 9.7 CR forged TRWs, Weiand Action+, Edelbrock 1901 Q-Jet, GK 270 cam, Magnum rockers, Jacobs Omnipack, 1-3/4" Hedders & 3" Warlock header mufflers, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, LT MegaShifter, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Best 15.1/95.5 @ 5800' Bandimere.
Old May 31, 2001 | 08:10 PM
Blue91''s Avatar
Thanks, I figured the 12 41 had some signifigance but I didnt realize they were the tooth count on the ring and pinion.Well it looks like they are 3:42.You learn something everyday. Thanks for the help.
86IROC112
Sep 7, 2015 01:37 PM
hectre13
Aug 26, 2015 08:17 AM
johanlindgren
Aug 16, 2015 12:16 AM
happyhapka
Aug 15, 2015 04:42 PM
