TH-700R4 Differences
Old Jun 5, 2001 | 06:22 AM
thirdgencompta's Avatar
I have 2 transmissions. A 1986 TH-700R4 and a 1988 TH-700R4. What is the difference between them? I heard somewhere that in 1988 they made em stronger, and I an under the impression the a 1988 is a 30 spline and a 1986 is a 27 spline. How can I tell? Which one is the best to use? Any comments would be appreciated.
Old Jun 5, 2001 | 06:42 AM
JoelOl75's Avatar
Car: 88 Firebird WS6
Actually they both should be 30 spline on v8's.
The differences range from more vanes in the pump and other pump mods to larger sprags, hardened planetaries, a better valve body.....
If you have a choice go with the 88. If the 88 trans is shot put the 86 in for now and do/have done a good performance rebuild on the 88 if your're planning on putting serious power through it.
As for bolt up differences, they are alike.
If you need to determine a good trans from a older (weaker) trans, pop the pan and look at the valvebody. There should be a metal tube running from the pump to the rear of the case (into an aux valvebody, made of aluminum) The older trans had a 'blockoff' plate installed at the back. That's prolly the easiest way to tell, but a later tranny thats shot isn't better than a earlier model in good condition.
Hope this answers your ?'s
69GTOby
Apr 18, 2016 02:34 PM
BAMiller
Sep 14, 2015 06:38 PM
Numbah-1
Sep 12, 2015 08:57 PM
J.C. Denton
Sep 8, 2015 05:35 PM
greenyone
Sep 2, 2015 03:39 PM
