precision industries torque converter?
Old Jun 6, 2001 | 06:07 PM
MattW's Avatar
Car: 1984 Trans Am
Engine: Vortec 355
Transmission: TH-700R4
Axle/Gears: GM Axles and GM 3.73
hey have you seen these torque converters in car magazines....they say "smoke your tires like never before. The VIGILANTE'S torque multiplication epualsan increase of up to 50 HP at the rear wheels. You'll decrease your 60FT. time and over E.T. up to 1/2 second"
has anyone tried this torque converter b4??
does anyone know how much it would increase mine?
if you dont know what im talking about look in either go to the website www.converter.com or check out the july 2001 issue of chevy high performance pg.112
84TA T-tops L-69 305HO TH-700R4 stock 190hp and 240 ft-lbs.
best E.T. (dont laugh) 15.997 @86.04mph
Old Jun 6, 2001 | 09:55 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Any torque converter will help a car that has had modifications done to it. A stock converter is designed for a stock engine. Converter selection is always "you get what you pay for" Although a medium stall converter can run from $200-$400, a good race converter may start at $800. Stall speed selection also depends on your car and engine. Just because someone gained .5 with a specific converter doesn't mean you will also. Stall speed should be a couple of hundred rpm higher than your peak torque.
When you look at stock eliminator cars. They dyno the engine before selecting a converter.
You can use an off the shelf converter and get improvement but your best choice is to contact the converter manufacture. Once they have all the information about your car and engine, they will suggest the best converter for your application.
I use a JW 3800 stall 10" Sportsman converter. It had close to the stall speed that I needed and was cheap because it isn't designed for NOS or a transbrake. The converter I'm probably going to have to get, once I get a transbrake, will cost twice as much as this JW converter but as I mentioned before. You get what you pay for.
Follow my racing progress on Stephen's racing page
and check out the race car
87 IROC-Z SuperPro ET Bracket Race Car
461 naturally aspirated Big Block
Best ET on a time slip: 11.242 altitude corrected to 10.89
Best MPH on a time slip: 121.52 altitude corrected to 125.89
Altitude corrected rear wheel HP: 481.6
Best 60 foot: 1.546
Racing at 3500 feet elevation but most race days it's over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car, 91 454SS daily driver, 95 Homebuilt Harley
88rscamar0
Sep 23, 2015 09:08 PM
Ragtop Man
Sep 12, 2015 12:23 AM
Nick McCardle
Sep 10, 2015 08:36 PM
89fast5oh
Sep 8, 2015 09:55 AM
