Back-up lights non functional
Old Jun 11, 2001 | 09:39 PM
SGT SWEETPANTS's Avatar
My tranny blew up and I replaced it with another T-5. Ever since then my back-up lights have not worked. I figured something was not connected in the process and I would check later. I put my headers on this weekend and searched the tranny over and did not see anything out of place. Can someone direct me as to where I can find the connection on the tranny (and where the wire that connects to it might be coming from). I also wondered if it could be a fuse. If so, let me know. Thanks in advance.
Andy
'86 IROC-Z, 305 LG-4, T-5, T-Tops, 50k Original Miles, K&N Air Filter, Jet chip, KYB Shocks/Struts, Centerforce Dual Friction, B&M Ripper Shifter, Hooker Shorties, Flowmaster Y-Pipe, Catco Converter, Flowmaster 80 series, 3 inch custom exhaust
Old Jun 11, 2001 | 10:51 PM
84 Z-28 350's Avatar
Car: 84 Z-28 Camaro, 2022 2500 silverado
Engine: 383
Axle/Gears: richmond 3.73, eaton posi
check to make sure you have the right case with the right paw there are 2 size holes and there are 2 diffrent reach sending units for the transmission. I had a case with the smaller hole (shorter sending unit) and the paw was for the longer sending unit so I ended up drilling out the hole for the longer one. (by the way it's pipe thred)
colton_carlson
Mar 8, 2019 12:21 PM
dibella989
Sep 1, 2015 04:12 PM
Jae992
Aug 27, 2015 09:07 AM
mustangman65_79
Aug 11, 2015 03:17 PM
Omega
Aug 10, 2015 12:46 PM
