Need Posi unit parts.
Car: 84 Z28 and a 95 Z28
Engine: Built 350 sixty over
Transmission: W/C T-5
Axle/Gears: 4:56s auburn posi, mosers, girdle
Does anybody know where i can get new clutches for my limited slip posi 7.5' 28 spline? I hear that you cant get any. I also looked in my service manual and it says that they are non rebuildable. Would appreciate some advice. Really can't afford to buy a new auburn at the moment. Thanks
Re: Need Posi unit parts.
The Auburn can not be rebuilt. It has steel cones attached to the axle gears. These cones run inside a taper that is cut into the case. The metal wears away and can not be replaced. When an Auburn wears out it is scrap metal. I recommend replacing it with a new Eaton posi and forget about another Auburn.
Car: 87 TA clone
Engine: 70/70 Turbo 5.3 LS
Transmission: bullet proof 2004R
Axle/Gears: ford 8.8, 3.55 gears
agreed. auburns when they wear throw CR@P all in the diff fluid and case. basically metal shavings. look at a trac lock or locker or clutch type posi like EATON. they are more expensive but stronger and rebuildable.
Yea i just took it apart last night. I didn't even think about it being a cone style posi. Never messed with one before just clutch ones. Now i know lol thanks for the advice
georgiaslim45
Sep 9, 2015 08:12 PM
georgiaslim45
Sep 9, 2015 08:11 PM
