Rear making noise
Old Jun 15, 2001 | 09:08 PM
Viking's Avatar
Car: / 89 IROC /
Rear making noise
My rear is making a noise that sound sort of like a truck with high knobby tires going down the road. I orginally thougt it was the axel bearings so I replaced them, but it turned out I was wrong. I feel it could be a pinion bearing, any suggestions?
Thanks in advance...
89 IROC original owner, 3 amplifier 8 speaker Kenwood/Infinity sound system, 305,000 miles on original 305 TPI. Change your oil!!!
Jeff's IROC Restoration
Old Jun 16, 2001 | 11:20 AM
Jay 727's Avatar
Yes it could be pinion bearings, it could even be front wheel bearings.
If it does it worse when accelerating or decelerating it's most likly the pinion bearings. It could also be the transmission but I doubt it, start with the easy stuff first. Have you greased your front bearings lately? I had a car I swore had a bad rear but turned out to be a front wheel bearing, thats the easiest place to start. Good luck .
theshackle
Sep 17, 2020 08:26 AM
B_Dubya
Aug 26, 2015 05:09 PM
bbsr72
Brakes
Aug 12, 2015 10:44 AM
BlackBoulder
Aug 11, 2015 11:15 PM
z28addict8490
Aug 7, 2015 08:48 PM
