trans swap
Old Mar 17, 2009 | 06:47 AM
zacks89's Avatar
Car: 89 iroc
Engine: beefed 355 for now
Transmission: 700r4 for now
trans swap
if i want to swap my 700r4 for a th350 will the hurst changeover kit be enough or will i need additional stuff to make work?
Old Mar 17, 2009 | 07:59 AM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: trans swap
you need to compare overall lengths of the 2, the TH350 was offered in 3 different overall lengths, and you may need a shorter or longer driveshaft.
Old Mar 17, 2009 | 08:02 AM
zacks89's Avatar
Car: 89 iroc
Re: trans swap
ok ill measure the th350. maybe a yoke adapter too? will i need a new cross member?
Old Mar 17, 2009 | 08:14 AM
zacks89's Avatar
Car: 89 iroc
Re: trans swap
also how is this gonna effect my acceleration? are my 3.73 gonna be good enough? do i still need a kick down cable(they suck)
Old Mar 17, 2009 | 10:48 AM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: trans swap
yoke adapter? a TH350 with a 3.73:1 axle will accelerate like a 200-4R with 3.42:1 or a 700R-4 with 3.08:1, but you still get the horrible gas mileage of 3.73:1 but no overdrive and no lockup. You do have to run a kickdown cable. The TV cable from a 700R-4 will NOT work. The only way to avoid any cable from the engine to an automatic trans is to swap to a TH400, or a 4L60E or 4L80E.
Jorlain
Aug 24, 2022 05:11 PM
midge54
Sep 2, 2020 07:13 PM
jharrison5
Aug 19, 2015 05:53 PM
mizz0313
Aug 12, 2015 06:45 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
