Anyone know what year the rear pinion bearing size changed in 9 bolt rearends?
Old Mar 19, 2009 | 03:44 PM
antman89iroc's Avatar
Car: 89 IROC
Engine: 6.8 HSR N2O
Transmission: TKO 600
Axle/Gears: 9" Moser 3.50 True trac
BW used different size rear pinion bearings (the one closest to the gear) on the 9 bolt rearends. Does anyone know what year they changed?
I have an 89 IROC with a 9 bolt rearend that I swapped out a few years back. I notice the rear pinion bearing in the 9 bolt that I installed was smaller than the one in the rear I took out (89).
Now, I'm switching out the ring and pinion on this "mistery" 9 bolt and need to buy a ring gear install kit and the tech at National Driveline shows only one bearing size so I need to identify the year (range) of the rear I have. Is there a date code on the axel housing?
Frozer!!!
Jan 19, 2024 04:55 PM
hectre13
Dec 11, 2023 08:14 AM
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
kyleb24
Aug 15, 2015 08:24 AM
knight72
Aug 10, 2015 09:32 PM
