v6 transmission and drivetrain hooked up to V8
Old Mar 23, 2009 | 12:42 AM
Stevobass's Avatar
Hi, I have a 86 with the LB8 V6 in it, would the 5-speed and the drivetrain thats hooked up in it be able to handle a 350 5.7l V8?
Old Mar 23, 2009 | 01:41 AM
crytical point's Avatar
Car: 92 RS Camaro
Engine: 305 TBI
Axle/Gears: 3.08
Re: v6 transmission and drivetrain hooked up to V8
BOOM!
No seriously the WC T5 wasn't put behind the 350 on standard production model because it was weak so let alone a V6 trans. Rear axle and drive shaft will be good but that trans will have to be replaced with a beefier unit like T56 or TKO or you could go off the walls and use the M-22.
Old Mar 23, 2009 | 02:07 AM
gregsz-28's Avatar
Car: 85 Camaro
Engine: No
Transmission: No
Axle/Gears: No
Did the v6's and v8's both use the WC t-5? The v6 has lower gears, right?
Old Mar 23, 2009 | 10:09 AM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
It can be done, but don't. Your driveshaft and rear axle are a bit stronger, and should be fine up to maybe 350 rwhp.
Old Mar 23, 2009 | 12:39 PM
Stevobass's Avatar
what about a 700R4 out of an 88 with V6?
Old Mar 23, 2009 | 02:37 PM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
won't bolt to the V8
Hotrodboba400
Dec 10, 2019 07:07 PM
RyanJB
Members Firebirds
39
Nov 20, 2018 03:30 PM
Zeek1041
Theoretical and Street Racing
Sep 30, 2015 11:00 AM
angel2794
Sep 8, 2015 06:22 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
