Tremec TKO 5- Speed Manual Transmission
I have a 1982 Camaro, next summer I will have my Small Block Chevy 383 built up. The car will be pushin about 500hp & tq. Tremec claims that this tranny can handle 525lbs of tq. I was just wondering what you guys think and if anyone has used this transmission, and how do you like it. Does it really hold up. I know it depends on how you drive also. Any input would be greatly appreciated.
Thanks,
Justin
1982 Camaro 383
350 Small Block Chevy, 9.6.1 Compression Ratio, Comp Cams 280H (Power Band 2000-6000 RPM), Rhoades Variable Rate Lifters, GM Performance Parts Drilled and Tapped Vortec Heads, GM Performance Parts Aluminum Self-Aligning 1.6:1 Ratio Roller Rockers, Edelbrock RPM Air-Gap (Non-EGR) (1500-6500+ RPM) Intake Manifold, Edelbrock Victor Series Aluminum Water Pump, Holley 4160 750CFM Carb, March Performance Deep-Groove Pulleys & Brackets (Crank, Water Pump & Alternator), Mobil 1 Tri-Synthetic 15W-50 Motor Oil, K&N 14"X4.5" Filtercharger with K&N Xtreme Top, MSD Electronic Distributor Part# 85551, MSD Blaster 2 Coil, MSD 6AL Ignition Box with Rev-Limiter, MSD 8.5MM Plug Wires, Sanderson Cast Iron Headers Part #QP1200, Custom 3-inch Aluminized Steel Exhaust Tubing, Flowmaster Part# 43083 with Single 3-inch Inlet and Dual 2.5-inch outlet 80-Series Muffler, TH 350 Tranny, 3:73 Posi Rear End Gears, Harwood Outlaw Z Fiberglass 4" Cowl Induction Hood
Thanks,
Justin
1982 Camaro 383
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Yes, the Tremecs are very good transmissions.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.23 @ 107.62 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
1991 Camaro Z28
13.23 @ 107.62 MPH
Southern California
bjpotter
Jan 22, 2019 12:27 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
