Should i buy this stall?
Car: 1985 IROC
Engine: lb9
Transmission: 700R4 B&M shiftkit
Axle/Gears: 3.42s
I'm looking to put a stall behind my newly built 355. A guy is selling a precision industries 3200-3600 stall converter. It is for 4l60e transmission but he says it will work with 700r4s. My transmission is a 1985 700r4. Will it fit?
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: Should i buy this stall?
There's a changover year for the 700R4. The input shaft size is different between the years. Pre 84 uses a 27 spline shaft. 84-97 uses the larger 30 spline shaft which includes the 4L60E
What's the total duration of your camshaft? You don't want a converter that stalls higher than what you need.
Car: 1985 IROC
Engine: lb9
Axle/Gears: 3.42s
cam specs:
cc306
230/244 duration at .050 lift
290/306 advertised duratioin
.510/.540 lift
112 lobe seperation
cc306
.510/.540 lift
112 lobe seperation
Car: 87 IROC L98
It would work but you might want a converter that stalls in the 3800-4200 range.
BumpaD82
Feb 26, 2016 02:57 PM
MikkoV
Sep 9, 2015 04:25 PM
