Should I be worried? (rear end noise)
Old Jul 2, 2001 | 10:29 PM
BlackBird305's Avatar
ok my torsen posi and richmond 3.73's are installed and i get a slight whine when i hit 1500 rpms and it gets louder the harder it turns...its been that way for about a month now...its not like a missle lauching whine more of a hum...u cant really hear it unless the windows are up or your listening for it...like i said its been about a month now so is that just the way its gonna be or what?...doesnt bother me as long as everything is ok...thanks
Old Jul 2, 2001 | 10:52 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
If it's always done that since it was put in and isn't changing then it's probably OK. Just get used to it.
ICON Motorsports
Old Jul 3, 2001 | 10:22 PM
JP84Z430HP's Avatar
Car: 84 Z28
Engine: 355 (fastburn heads, LT4 HOT cam)
Axle/Gears: 9-bolt, 3.27
Some aftermarket gears make a little noise. No way around it!
Working on:
'84 Z28 LG4 305 with 207,000 original miles!
Dual electric fans (from a formula).
145 MPH IROC Speedo
430 HP 350 (ZZ430) Coming soon! (Building it myself, so I don't get those AWESOME valve covers!)
Starting to look like the Kicker poster child!
ASE Certified Master Tech
+ L1 Advanced Engine Performance
+ X1 Undercar Specialist
And....A sig. that's getting way too long!
Old Jul 3, 2001 | 10:23 PM
OLDYELLR's Avatar
Car: '85 IROC
Some people claim Richmond gears whine more than GM and some say it's due to the stronger tooth design. I had mine replaced with Richmonds when I found they were self-destructing after I broke my posi and I would have to use a lot of imagination to say that they whined. Maybe it depends how good the installation is. Dump the oil and see if it's turned dark grey from metal particles, then change it again after a few hundred miles to see if it's staying clean.
1985 Yellow IROC-Z 5.0 HO, T-5 3.73 Torsen, 4 wheel disks
PFCM pads, GTA wheels, Koni yellows, B&M Ripper, Dynomax
Old Jul 4, 2001 | 08:29 AM
purpleworm's Avatar
I wouldn't worry about it too much. I just had to swap my rearend because it was whining though. Mine was whining when I was just barely rolling though LMAO! The one I have now makes a bit of noise but it sounds alright. If you are really concerned change the oil(already said) and if you are really worried I would get the pattern checked just to double check. The guys that did my last rearend shimmed it too tight I thing and the pinion seal weaped and now the rearend is toast.
Old Jul 4, 2001 | 09:07 AM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
I think thats just the way Richmond gears are. I have heard from several sources that Richmond sacrifices noise for durability (remember, they make racing gears, not gears for your grandmothers caprice station wagon).
I have installed Richmond gears on my car, and I would like to think I did a "professional" job. Backlash and tooth pattern are right on the money, and I get the "whine" between 30-55mph. I have put about 10,000 very hard miles on them with about 7-8 trips to the dragstip, and still work great. I wouldn't worry about it.
If you live in Southeastern US, check us out!
South East Thirdgen
GM Master Tech
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey,
22# injectors,
Whatever chip I feel like burning,
JET AFPR, Ported Plenum,
TB Coolant Bypass, Custom Cold Air,
SSM SFC, KYB Shocks, Boxed LCAs, Wonder Bar,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
3.73 Posi
4wheel Disc Brakes
Summit 1-5/8" headers, 2.5" Dynomax catback.
Best 1/8: 9.519@72.74
'97 Bonneville SSE
hectre13
Dec 11, 2023 08:14 AM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
hectre13
Aug 26, 2015 08:17 AM
Jlanz55
Aug 17, 2015 07:15 AM
BlackBoulder
Aug 11, 2015 11:15 PM
