High clutch Engagement
Car: 1991 Camaro Z28
Engine: Dart SHP 406ci T88 turbo
Axle/Gears: QP 35 spline Ford 9" 3.50 gears
I installed a brand new Zoom High Performance Kevlar clutch set for my WC T5 and after driving around I noticed that it has a very high clutch engagement. I would say that it engages at about 90-95% release point. It uses a hydraulic clutch slave cylinder so adjustments cannot be done. Do you guys think that maybe the clutch fork is bent? It seems like a pretty solid piece and doesn't look bent. Also, the throwout bearing rattles when I take my foot off the clutch pedal. If I rest my foot on the pedal the rattling goes away. The bearing is also new(came with the kit). Any input is greatly appreciated.
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: High clutch Engagement
the pivot ball could be out of adjustment
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Drone358
Dec 10, 2015 08:16 PM
Night rider327
Sep 2, 2015 04:17 AM
