Rear Differential stuff.
Old Apr 2, 2009 | 02:50 PM
aletheian's Avatar
Car: 1985 Trans Am
Engine: v8 305
Transmission: reverse valve
I was getting my car inspected today, and they recommended that at somepoint in time I replace the rear diff. cover.
They also told me that there is a whine in the rear diff. when on the throttle.
Is the whine because of the leaky cover? Or do I need a rear differential?
What steps should I go about taking to do this myself. Or should I have a garage to do it?
Also, they told me there is a vibration when braking, any thoughts on what that would be?
Old Apr 2, 2009 | 03:01 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Rear Differential stuff.
Originally Posted by aletheian
Is the whine because of the leaky cover? Or do I need a rear differential? What steps should I go about taking to do this myself. Or should I have a garage to do it? Also, they told me there is a vibration when braking, any thoughts on what that would be?
If the cover leaks, there may be no gear oil in the diff. I'd check that first. This is something you can do:
https://www.thirdgen.org/forums/tran...ing-axles.html
The rotors could easily be warped.
JamesC
Old Apr 2, 2009 | 08:00 PM
aletheian's Avatar
Car: 1985 Trans Am
Engine: v8 305
Thanks for the reply. I will try this out, I do not hear the whine but the guy inspecting the car claimed he heard one.
Old Apr 3, 2009 | 06:57 AM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Just don't take it back to the place that did the inspection. Check & change flulid and replace the cover gasket. Unless the cover was damaged they are not a wear item that needs replaced.
Old Apr 3, 2009 | 07:41 AM
aletheian's Avatar
Car: 1985 Trans Am
Engine: v8 305
I talked to my father yesterday, (who is probably the best mechanic I know) and thats the exact same thing he told me to do, so I think we will try that out.
1992 Trans Am
May 10, 2023 07:19 PM
NORTz89
May 20, 2020 03:51 PM
E Rod
Aug 28, 2015 05:17 AM
LT1Formula
Aug 20, 2015 09:36 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
