Will a posi from a third gen work in my 4th gen?
Old Apr 3, 2009 | 10:35 PM
Epro's Avatar
Car: 95 Camaro Z28
Transmission: 4L60E w/ shift kit
Axle/Gears: 3.23s
My camaro is a 95, 3800 series II, has an open diff. Embarassing one wheelie peelies. Occasionally spins two.
4th gen parts cars are hard to find, hoping to score a posi unit out of an older third gen car.
Old Apr 3, 2009 | 11:13 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: Will a posi from a third gen work in my 4th gen?
Only a posi from a 90-92 will work. Earlier versions are made for 26 spline axles. 90+ F-bodies use 28 spline axles.
You can also find one from a 90+ S10
Old Apr 4, 2009 | 12:55 AM
Epro's Avatar
Car: 95 Camaro Z28
Axle/Gears: 3.23s
Awesome! What is the cut off year for the S10s and what models had a posi?
Old Apr 4, 2009 | 06:54 AM
big gear head's Avatar
You don't want anything from the S10. They got the Governor Lock, which has a lot of small parts in it that break easily. You will be much better off getting a 4th gen rear end. The 3rd gen used the Auburn, which isn't the best choice. They wear out quicker than others and can not be rebuilt. Look for a 4th gen with the Torsen diff, or get a new Eaton Posi. You will also need to get the right series for the gear ratio that you have. If you have a 3.08 to 2.41 then you will need a 2 series. If you have a 3.23 to 4.10 then you will need a 3 series.
Reddeath210
Oct 6, 2015 08:20 AM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
