flywheel teeth
Old Jul 17, 2001 | 04:41 PM
STL1994's Avatar
flywheel teeth
when my friend switches from L69 to a carbed 350, hes gonna get a new flywheel, but i see that there are 153 tooth and 164 tooth, which one should he be ordering? its a 1986 Camaro with a L69 700R-4 :-) thanks
Old Jul 17, 2001 | 05:47 PM
87RS402's Avatar
First off, it's a flexplate. Flywheels are for manual transmissions.
Is the new engine a 2pc or a 1pc rear main? 86 was a 1pc IIRC. That said the old one should be fine if the new engine is a 1pc rear main also. If he "has" to have a new one there is a simple way to tell them apart. 153 teeth = 12 3/4" 168 teeth = 14". Alternativly look at the starter bolt pattern, if the bolts are diaganol it's a 168, if they are straight across then, most likely it's a 153, could be a 168.
Old Jul 17, 2001 | 10:48 PM
STL1994's Avatar
flywheel flexplate smae thing lol well its the older style 71-85 block
Old Jul 17, 2001 | 10:50 PM
STL1994's Avatar
so does that mean i need a 153 tooth flexplate?
Old Jul 18, 2001 | 12:53 AM
87RS402's Avatar
<font face="Verdana, Arial" size="2">Originally posted by STL1994:
flywheel flexplate same thing lol ...</font>
Different things almost completely, not anywhere near interchangable, and the flywheel costs about 4 times as much.
I'm not real sure what size he has right now. I have a 5-speed, so I know mine is the 153. The slushbox on the other hand IIRC can use either one. The best way to tell is look at the bolts, they should clue you in.
Old Jul 18, 2001 | 09:31 AM
STL1994's Avatar
"flywheel flexplate same thing" i was being sarcastic lol
anyway, thanks, ill look at the bolt pattern and see what it has, but should i be using the same flexplate style? it has the 1 pc seal right now, and im going to the older 2 pc design, so is it safe to use the same style on the old motor?
Old Jul 18, 2001 | 01:03 PM
87RS402's Avatar
You will have to get a new one. The bolt pattern is different between the two so it will not bolt up. Other then that just get one the same size as the one you have now.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
gord327
Oct 3, 2015 01:25 PM
Vincent135
Sep 28, 2015 10:50 PM
mfp189
Sep 27, 2015 09:25 AM
monte87cortez
Sep 26, 2015 08:10 PM
