94/93 lt1 t56 flywheel questions
Old Apr 9, 2009 | 09:15 AM
toy4x4's Avatar
Car: 86 IROC Z28
Transmission: 94-T56 6speed
I have a 86 305 TPI with the 94/93 lt1 flywheel. (I did a t56 conversion.) My t56 broke and I need to know if a t5 clutch will work on this flywheel. Also if not will a flywheel from a 94 v6 3.4l fit my 305 and will it be weighted properly?
I have access to a t5 from a 94 3.4 v6 car. I also have a camaro v8 t5 bellhousing. I just need to know if the flywheel I have is compatible with the v6 clutch and clutch plate. Or if not Will the flywheel from the 94 v6 car fit my 86 305 TPI motor?
Also If I find a 82-92 v8 t5 will the stock clutch and clutch plate fit and work with my flywheel? Seems like somewhere I read that a 3rdgen t5 flywheel is different from a lt1 t56 flywheel because of the pull style clutch. If this is true then what is the difference?
Old Apr 9, 2009 | 10:15 AM
85MikeTPI's Avatar
Car: 1985 Camaro Z28, VIN F
Engine: 427 sbc, HSR
Transmission: T-56, self rebuilt 700+ hp
Axle/Gears: Moser 12bolt, 3.42 trutrac
Re: 94/93 lt1 t56 flywheel questions
- Fix the T56 ???
There is a T5 FAQ/Sticky that will answer alot of your questions. The T56 Clutch/FW is unique (pull-type).
BlackphantomZ28
LSX and LTX Parts
Oct 19, 2015 06:25 PM
BlackphantomZ28
Aug 31, 2015 10:29 AM
redmaroz
Aug 16, 2015 11:40 PM
sreZ28
Aug 14, 2015 07:48 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
