Torque Arm Bracket on 700r4
Old Apr 10, 2009 | 12:30 PM
iggy89's Avatar
Car: 86 Camaro
Engine: 79 350 carbed
Transmission: TH-350
Axle/Gears: 3.73 posi
Ok well I am in the middle of installing my 700r4 into my car and I kind of ran into a problem. I ended up buying a tranny without the holes in the tail shaft for the bracket. I didn't even think about it since I never had seen this tranny in the car. Soooo I bought the parts to take hold of the arm. If I try putting it on without going through the 2 holes do you think I will run into problems? I would just need to make a plate so it can hold onto the tail shaft and then the one screw that is next to the speedo would then be on the bracket also. I just want to make sure I won't bust off the tail or anything. I am just looking for somewhat of a temporary fix for now. I might look into going with an aftermarket crossmemeber with the torque arm bracket on but the only problem with that I would probably have to do some heavy modification to the exhaust since the crossmemeber usually come thinker than stock.
Old Apr 10, 2009 | 01:00 PM
akmusclecar's Avatar
Car: 1988 Pontiac Firebird
Engine: 5.0 TBI
Transmission: W/C T5
Axle/Gears: 3.08 Posi
Re: Torque Arm Bracket on 700r4
Check UMI performance for a tunnel mounted torque arm mount. That would be my suggestion.
Hotrodboba400
Dec 10, 2019 07:07 PM
New2Chevy
Sep 28, 2015 12:35 AM
TheTraut88
Sep 7, 2015 05:22 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
