L98+ Slicks, Can the diff handle it???
Old Jul 15, 2001 | 09:57 PM
JaysZee's Avatar
Car: 91 Z28
Engine: 5.7L
My engine is fairly stock- K&N's, 24# injectors, cat-back, air foil. Can the stock rear end handle slicks??? Thanks
1991 5.7L Z28
14.456 @ 92.78 MPH
Old Jul 15, 2001 | 10:14 PM
CamaroMike's Avatar
Check my sig! I run those times on a stock 26 spline 7.5" ten bolt!
84 Camaro ZZ4 with HOT cam. Ported Heads, Installed Larger Race-Flo Valves, RPM Air Gap Intake, and 1 3/4" SLP Headers (Best 60',Quarter Mile, MPH) (1.88, 12.91, 106.77)
Other Mods: You name it and I have probably changed it.
2001 Dodge Ram Quad Cab 5.9L 4*2
The Bowtie
ASE Certified Auto Tech
LIVE AND DIE BY THE ALMIGHTY BOWTIE!
Old Jul 16, 2001 | 12:08 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Well let's look at it this way.... a LS1 4th gen has a 10-bolt with the exact same internals as a 3rd gen has; they run very low 13s to high 12s; I'd say that with a L98 about 1½ seconds off that pace, you're probably OK, especially with an automatic and stock converter. You've got a ways to go before you have to get really concerned.
ICON Motorsports
Old Jul 16, 2001 | 11:30 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
I still use a 10 bolt. The axle tubes are welded, LPW Ultimate rear cover and 28 spline aftermarket axles but it's still a 7 5/8" ring gear.
I'm still expecting it to explode but until it does I'll keep runningit.
Follow my racing progress on Stephen's racing page
and check out the race car
87 IROC-Z SuperPro ET Bracket Race Car
461 naturally aspirated Big Block
Best ET on a time slip: 11.242 altitude corrected to 10.89
Best MPH on a time slip: 121.52 altitude corrected to 125.89
Altitude corrected rear wheel HP: 497.9
Best 60 foot: 1.546
Racing at 3500 feet elevation but most race days it's over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car, 91 454SS daily driver, 95 Homebuilt Harley
Old Jul 19, 2001 | 11:32 PM
twistedwedge's Avatar
Car: 87 GTA
Engine: 355 Chevy
i snapped a stock 26 spline axle when i tried slicks.....car didnt even move enough to trip the beams... the 4th gen cars have 28 spline axles, i think theyre stronger. I probably wont attempt a slick pass again until i install my 12-bolt.
Old Jul 19, 2001 | 11:34 PM
Car: 87 GTA
Engine: 355 Chevy
<font face="Verdana, Arial" size="2">Originally posted by Stephen 87 IROC:
</font>
are you using automatic or manual trans?
Old Jul 19, 2001 | 11:56 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Automatic with a 3800 stall converter and no transbrake
[This message has been edited by Stephen 87 IROC (edited July 19, 2001).]
Linson
Oct 24, 2025 02:00 PM
Numbah-1
Oct 2, 2015 08:27 AM
