700r4 hammering noise
Old Apr 10, 2009 | 09:30 PM
turners1362's Avatar
Car: 86 Z28
Engine: 355
Axle/Gears: Stock 3.42
Brought home a 1991 formula 350 yesterday. Bought the car not running (stupid? maybe). Got the engine started last night and there was a loud hammering sound from the rear of the engine. My first thought was torque converter bolts might be loose. Checked it today and sure enough one was backed out about half way. Tightened all of the bolts and the noise is still there. So I removed all of the bolts from the converter and pushed it back, ran the engine, and no more noise. Has anyone ever experienced a failure in the front of the 700 trans that could be similar to this?
I put the car in gear and it engaged forward and reverse. Didn't drive it though because the engine has some bugs left to work out ->stalls when put in gear.
On a side note-The converter looks like it might be a B&M, judging by the dark blue color (could be anything I guess). Anyone know if B&M converters have a part number or something to I.D. them?
Thanks,
ST
Old Apr 10, 2009 | 10:06 PM
Thirdgen89GTA's Avatar
Car: 1989 Trans Am GTA
Transmission: M28 T56
Re: 700r4 hammering noise
Thanks,
ST
This may not be it. But its just a theory. Is the trans mount bad? Look for cracks and rips in the rubber where the tailshaft meets the crossmember. First time it happened to me in my GTA it scared the crap out of me. It ripped on a WOT upshift from 1st to 2nd.
Old Apr 11, 2009 | 09:11 PM
Car: 86 Z28
Engine: 355
It's probably worth a look. Did it make noise just sitting in park and revving the engine?
Thanks,
ST
Old Apr 16, 2009 | 08:57 PM
Car: 86 Z28
Engine: 355
Today I figured out that if I pull the TV cable the noise goes away. Also, when the throttle is put to WOT the cable is stopping it before it gets there. I adjusted the cable all of the way out (toward the front of the car) and now it will allow WOT.
Anyone have a thought as to what this might be?:?
Wrong TV cable maybe? My information says there should be a metal set button/tab on the cable. The one on the car has a plastic c-clip that must be pryed out with a screwdriver.
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
no green
Jan 9, 2016 09:22 PM
sleprock
Interior Parts Wanted
Oct 3, 2015 11:01 PM
sjorgens
Oct 1, 2015 07:54 PM
6998poncho
Sep 25, 2015 02:56 PM
