9 bolt posi strength?
Car: 85 trans am
Engine: 383 stroker
Transmission: 5 speed
Axle/Gears: 9 bolt rear 3:70
i have a 9 bolt rear and i went out today and checked how much torque it takes to break one tire loose from the other and it was between 50-70 pounds depending on where the lug was positioned. how much does a new posi unit usually take? and should i be looking into getting new cones?
Car: 1989 Camaro RS
Engine: 1990 - 5.7
Transmission: Tremec 3550
Axle/Gears: 9 Bolt - 3:45
Car: 85 trans am
Engine: 383 stroker
Re: 9 bolt posi strength?
i have done the test i was just wondering if anyone knew how much torque it takes to beak one side loose from the other on a new unit. i think mine is pretty worn since it isnt very far from the limit but i wanted to see how worn it is from new.
Hotrodboba400
Dec 10, 2019 07:07 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
