4th Gen Clutch Cylinder Assembly - T-56 Swap
Old Jul 11, 2001 | 08:25 AM
Mark W. Winning's Avatar
I put a 4th gen clutch cylinder in my 92 Firebird when I installed my T-56. I also added a new clutch and pressure plate. Since I did the install, the clutch has always grabbed real high. My question is, is there anyway to adjust that down a bit?
Mark
1992 Pontiac Firebird 350/Six Speed
1987 Toyota Pickup 383/500+ HP
Old Jul 19, 2001 | 11:50 PM
twistedwedge's Avatar
Car: 87 GTA
Engine: 355 Chevy
ive got a 94 t-56 in my 87 t/a and my clutch releases almost 3/4 to the top...i think that the system being hydraulic there isnt any adjustment, anyone correct me if im wrong?
Old Jul 22, 2001 | 03:55 PM
PETE's Avatar
Car: 1989 TTA #1240
Engine: 3.8 SFI turbo
Transmission: 2004r
the only adj that can be made isn't really an adj. make sure the system doesn't have any air in it...you can bleed the system but iit's a pita
87 trans am,gm crate 350(4 bolt mains 10to1),L98 aluminum heads,LT4 hot cam,slp runners,slp 1 5/8 headers,3in.y-pipe,edelbrock base,hi flo cat,air foil,afpr,as&m ported plenum,gutted airbox,t-5 tranny w/centerforce clutch and a 3.27 9bolt(11.9in. brakes),ed wright's fastchip,relocated iat sensor,160 fan switch,tb bypass,accel supercoil,cap& rotor,hollowed maf,slp 3in. catback,a/c delete.
shooting for 13's!!!!!!!
14.10@97mph w/2.01 60'(auto ET)
slp catback is finally on!!!
fastchip prom is in.
kicks you in the A.S.S at wot.
FLOWMASTER S.U.C.K.S
1992 Trans Am
May 10, 2023 07:19 PM
Fast355
Dec 2, 2016 06:33 PM
25thannivZ28
Aftermarket Product Review
Jan 2, 2016 05:41 PM
redmaroz
Aug 16, 2015 11:40 PM
sreZ28
Aug 14, 2015 07:48 PM
