little ball screw....
Old Jul 26, 2001 | 12:08 PM
sunbound's Avatar
Car: 1987 IROC-Z
im puting a new clutch in and throw out berring in my camaro.... and on the bellhousing, their is a ball-screw thing that the throw-out berirng fork "pivots" on. does this have to be adjusted? if so, how should i have it? i forgot if it was all the way in the bellhousing before, or if it was out a bit... i really dont want to have to take the tranny out to adjust this thing, if i have it wrong when i have everything together again (the engine is out too).
thanx
sunbound
Old Jul 26, 2001 | 10:16 PM
Jay 727's Avatar
My opinion is that it's not too difficult to install the pivot ball tight and put it together to test it out, after all it is all out of the car right? engine and transmission? The throw out bearing should move at least 1/8 inch between the clutch and trans if not the pivot needs adjustment or you need a shorter throw out bearing.
Old Jul 26, 2001 | 10:33 PM
Engineboy's Avatar
Car: yep
Engine: uhuh
Transmission: sure does
I've never seen an "adjustable" pivot ball, as far as I know they all screw all the way in.
I have seen one that was left loose...it worked its way out and messed up the bell housing...
ASE Mechanic/Machinist/Smog Tech
1999 NBM Trans Am
1986 Chevy 3/4 ton pick up
1981 corvette
1995 Kawi ZX6R
and 2 POS commuters...
R.I.P. #3
"He can see air"
Ed1LE
Sep 30, 2018 09:14 AM
Thirdgen89GTA
Oct 19, 2015 09:27 AM
88CamZ
Oct 8, 2015 10:29 AM
loud91rs
Oct 5, 2015 10:05 PM
sjorgens
Oct 1, 2015 07:54 PM
