700R4 - T-56?
Old Jul 24, 2001 | 10:45 AM
BryanJ's Avatar
700R4 - T-56?
Please do not flame me for this post. I read all of the instructions in the tech article. It was for a T-5 to T-56. I was wondering what other parts I will need when going form 7R4-T56. I saw I will need a starter, steering column bracket, brake/clutch pedal. any other parts?
I just wanna make sure I have everything before I start.
Thanks,
Bryan
I also searched the archives!
[This message has been edited by BryanJ (edited July 24, 2001).]
Old Jul 24, 2001 | 08:02 PM
kevinc's Avatar
Car: 1982 Z28
I just did this very swap. Check these:
http://member.aol.com/macewen001/T56.html
http://icdweb.cc.purdue.edu/~trull/tranny.html
http://www.84transam.8m.com/pages/transswap.html
1982 Z-28
See http://www.mycar.net/mafb/registry/detail.cfm?id=276 for details
Old Jul 25, 2001 | 01:12 AM
BryanJ's Avatar
How hard was it? I am mechanically inclined enough to do this, I think. How much did all of the parts run you?
Thanks so much for the reply,
Bryan
Old Jul 25, 2001 | 01:25 AM
BryanJ's Avatar
One more thing how many hours do I need to set aside for it?
Old Jul 30, 2001 | 10:52 AM
kevinc's Avatar
Car: 1982 Z28
It all depends on your skill and the tools you have available to you, so I couldn't answer as to how long it will take you. I worked in segments listed below along with my approximate elapsed times:
1.) remove TH700-R4 and associated stuff: 2 hrs.
2.) install master cyl and brake pedals: 4 hrs. I lost time trying to do it without removing the power brake booster drum...just yank it.
3.) mock up T56 and bellhousing to mark trans tunnel cutout: 1.5 hrs. Rent a trans jack and this will go faster, I really fumbled around getting the trans in place.
4.) remove T56, cut trans tunnel, paint cut surfaces: 0.5 hr.
5.) install pilot bearing, flywheel, clutch, pressure plate: 0.5 hr.
6.) install bellhousing: .25 hr.
7.) install T56: 1.5 hr. Again, rent a trans jack with tilt and this goes much faster.
8.) install shifter, wiring, Dakota box, console, seats, etc. 2 hrs.
-Kevin
1982 Z-28
loud91rs
Oct 5, 2015 10:05 PM
92projectcamaro
Sep 29, 2015 07:07 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
indygene
Sep 26, 2015 11:21 AM
6998poncho
Sep 25, 2015 02:56 PM
