TH350C and TV Cable
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: TH350C and TV Cable
You can run without it if you don't mind the transmission never downshifting on its own when you step on the gas.
Car: 89 RS
Engine: 327
Transmission: T-350
Axle/Gears: 4:10 10 Bolt
T-350 does not use TV cable. What you are looking at is the kick down cable. Yes it is ok to use without it. Just will not down shift at full throtle. Vacuum line goes to modulator valve fo auto and manual shifting.
Z28/ZR1
Oct 23, 2015 01:04 PM
TMZIrocZ350
Oct 7, 2015 12:09 PM
rs_z28_vert
Sep 30, 2015 09:47 PM
