Those with fresh 700R4...how long between shifts?
Old Jul 31, 2001 | 10:42 PM
Steve10's Avatar
I'm so frustrated trying to tune this car in. I can't get the WOT 2-3, so I've been stopwatching 0-60mph times after I make a change. It's been working okay to see differences in FP and timing changes. I've plotted out the data from my scanner and it shows a consistent .8-1.0 sec. between the 1-2 shift. The RPM's are at 5200 then drop to ~3400 1.0 sec. later before it picks up again. Please tell me a performance rebuild is going to make a world of difference. Anybody know how long you spend between shifts and how many RPM's you lose? I can't wait to get this thing rebuilt. Also, I was doing the brakes yesterday and with the rear on jackstands and car running I shifted to neutral and the wheels were spinning just like in gear. I think the torque convertor is shot...that certainly doesn't help my idling in gear with this cam either.
'87 Formula WS6 - ZZ4 Crate TPI, ported heads, LT4 hot cam, 1.6RR, Accel runners, Accel lower, ported plenum, Edelbrock 58mm TB, pulleys, SLP cold air, headers and full exhaust, gutted cat, Walbro 255, Koni yellows, aftermarket panhard & LCA's.
[This message has been edited by Steve10 (edited July 31, 2001).]
Old Aug 1, 2001 | 04:22 AM
Pro Built Automatics's Avatar
Need more info.
rear end gear ratio
cam duration at .050 lift, etc.
please call me Dana 800-776-3288
Old Aug 1, 2001 | 08:28 AM
Steve10's Avatar
Cam= 218/228 .525/.525 112 LS
Rear= 3.27
morrow
Jan 13, 2024 12:29 PM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
LittleFranks
Sep 17, 2015 12:22 PM
g.l.mos
Aug 22, 2015 12:02 AM
