ATTN ProBuilt.......
Old Aug 5, 2001 | 01:42 AM
Mista's Avatar
Car: 1986 Trans Am
Engine: 305 TPI peanut cam
My 86 TA has a GM REMAN 700R4 (circ 1991) with updates that were current at the time. I'm starting to believe that a vette verter was installed at the same time. IF the rear brakes hold (damn non adjusting GM discs) I can flash to 2100-2200 rpm but normally I can only goto 1700 rpm before the rear tires start spinning while staged.
I have the lowly peanut cammed 86 LB9 motor with 107,000 miles on it. Launching at 1600 rpm I run consistant 15.6's @ 86-87 mph on Goodyear Eagle GT+4's and let tranny shift itself at 4600 rpm.
Did I just happen to get lucky???
I've seen tests of 88 350's only getting high 15's. Maybe I got a ringer????
Thanks for you time...
Honda D tranny guru myself...
86 T/A 5.0 A4 & 2.77 gear
15.62 @ 86 mph
93 Civic 1.6L
13.5 @ 100 mph
Old Aug 5, 2001 | 08:43 AM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
I'm not Dana, but I think I can answer this. Your launch speeds sound about right. Most people think that "all remans are the same" and that simply isn't true. In 1987, Hydramatic really stepped up the transmission division and made some really good changes (not only to the tranny, but how they were built and parts used, etc...) So if you ordered a tranny for your 1986 Trans Am, you got all the parts and updates for your specific application.
As for your track times, they sound about right. The 350 times may be a little high. Stock, they are usually good for low 15's, high 14's/
FREE CARFAX Record Check
If you live in Southeastern US, check us out!
South East Thirdgen
GM Master Tech
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey,
22# injectors,
Whatever chip I feel like burning,
JET AFPR, Ported Plenum,
TB Coolant Bypass, Custom Cold Air,
SSM SFC, KYB Shocks, Boxed LCAs, Wonder Bar,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
3.73 Posi
4wheel Disc Brakes
Summit 1-5/8" headers, 2.5" Dynomax catback.
Best 1/8: 9.519@72.74
'97 Bonneville SSE
Old Aug 6, 2001 | 07:41 AM
Mista's Avatar
Car: 1986 Trans Am
THX!!!!...
Also a local guy is selling a 1987 WS6 3.27 9 bolt rear for $250.
Perfect for new gears
It has rear disc some it sold be a easy swap right? It has no ebrake brackets, but I'll just use mine.
15.62 @ 86 mph
93 Civic 1.6L
13.5 @ 100 mph
[This message has been edited by Mista (edited August 06, 2001).]
R3500
Aug 24, 2015 09:05 AM
zippinz
Jul 10, 2007 11:14 PM
NEEDAZ
Car Audio
Jun 23, 2005 07:15 AM
