200c w/shift kit problems...
Old Aug 5, 2001 | 12:39 AM
phantazy82's Avatar
i was racing at the drag strip this weekend and my tranny started "bogging down" when shifting from 1st to 2nd....wether or not i shifted it manually or left it in drive...what could be the problem? i'd really like to get it taken care of soon.
1982 Camaro SC
Old Aug 5, 2001 | 03:55 AM
transfixleo's Avatar
Please be more detailed but from what you said it sounds like the Low Roller Clutch may have let go, jamming on. IF it can't overrun as it should after 1st gear it would bind up in two gears. You would still have reverse too.
Old Aug 5, 2001 | 04:03 AM
EvilCartman's Avatar
Car: '82 Z28
Where did you get a shift kit for that trany and what one did you get? I'd like to put one in mine just to hold me over.
Old Aug 5, 2001 | 09:09 AM
Try this: http://www.hptransparts.com/MM007.ASP?pageno=85
Keep in mind that this isn't a Boom-Boom kit but is intended to fix the many 200C tranny problems,and it does. It actually ends ip feeling like a decent 350 when installed but don't expect tire chirping shifts. Also, this is for '79-up. They don't have the listing here for the '76-'78 but I have some if you need it.
[This message has been edited by transfixleo (edited August 05, 2001).]
Old Aug 5, 2001 | 11:21 AM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
Huh, thats odd when I had the 200c I tryed to find shift kits and all I got was strange looks everwhere I asked. guss they do make them.
SSC
Old Aug 5, 2001 | 05:22 PM
You have to realize that when I use the term Shift Kit I DON'T mean a bang-shift kit, but a genuine TransGo Shift Kit (trademark). These are intended to FIX a particular transmissions common causes of complaints and failures, not to make it shift hard. That is why it is intended for all passenger car use. These are also intended for professional use so the instructions may seem a little complicated.
Old Aug 5, 2001 | 10:41 PM
phantazy82's Avatar
thanx for the replies....the shift kit was in the car when i bought it. as far as the tire chirping shifts, i'm not worried about that, i only have a 305. it just really made me concerned when i got the whole shot and had the tranny bog down when i shifted into 2nd....ended up losing the race
1982 Camaro SC
Old Aug 8, 2001 | 12:35 AM
Car: '82 Z28
Thanks for the info, any fix or improvement will be great for this thing lol
1Aauto
Sponsored Vendors
Jan 15, 2016 06:26 AM
1Aauto
Sponsored Vendors
Sep 22, 2015 03:39 PM
1Aauto
Sponsored Vendors
Sep 10, 2015 02:02 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
