ive got a 10 bolt open 2.73 and have a chance to buy a 9 bolt 3.40?(i thought it was 3.42) with positive traction. what are the pros and cons of the 9 bolt.
jp taylor
jp taylor
Ratio is probably 3.45
Good = fairly strong
Bad = very few parts available, brakes suck
ICON Motorsports
ICON Motorsports
The 9 bolt also has bolt in axles. No C-clips. It's superior to the 10 bolt except for it's major downfall, lack of parts and gear ratio avalability.
Ummmm....
They are stronger,
Parts are not hard to find anymore (but unfortunately they are still not that cheap),
My disk brake 9 bolt stops fine.
Actually, they are stronger because they have 4 spider gears and 2 side gears (instead of 2 and 2), have 28 spline axles (and I can get 'em in 31 spline version with a spool), they are a cone style posi vs clutches, they have disk brakes, they have axle retaining flanges instead of c clips, have disk brakes, they are better than a 10 bolt but not as good as a 9 inch, they are cheaper than a 9 inch but not as cheap as a 10 bolt, etc... It is somewhere between a 10 bolt and a 9 inch (or 12 bolt) in most every aspect, but then of course, I am biased
Miles
88 427 Camaro
12.18 @ 113mph 1.75 60ft
Currently installing 3.73's into my 9 bolt (YES,it is a 9 bolt & YES they are 3.73's, not 3.70. 4.11's to follow soon
www.koolmeister.com
They are stronger,
Miles
88 427 Camaro
)www.koolmeister.com
Kevin91Z
close
- Join DateJul 1999
- LocationOrange, SoCal
- iTrader Positive Feedback100
- iTrader Feedback Score(1)
- Car1990 Pontiac Trans Am
- Engine355 TPI siamesed runners
- TransmissionTremec T56
- Axle/Gears12-Bolt 3.73
- Liked:26 Times in 22 Posts
The brakes are the same in 9-bolts and 10-bolts, there is no difference. Except 9-bolts are all disc brakes.
82-88 is the smaller brakes, 89-92 is the larger brakes.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.23 @ 107.62 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
1991 Camaro Z28
13.23 @ 107.62 MPH
Southern California
