5'th gear has left the building WCT5
Old Aug 12, 2001 | 03:37 PM
fordcrusher's Avatar
after some comparative driving a month or so ago, my fifth gear decided to leave me. Is it very difficult to rebuild manual T's? Has anyone had the honor of cracking one of these open? It's an 89 bird, swapped out my 305 for the zz4, and at around 112 mph and hard pressed, the t5 gave up. I had to kick his *** in 4'th. It sounds like my slave cylinder is rotting out, so I figure while I'm changing the clutch I might as well do this too. thanks for any help!
Old Aug 12, 2001 | 11:50 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
What do you mean it left you? Are you getting a grinding noise? Or is 5th gear freewheeling? I had a problem with mine, where the snap ring for 5th gear came off, so the gear walked off the shaft. I opened it up, replaced the snap ring with a new one, and the problem was fixed.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.23 @ 107.62 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
Old Aug 14, 2001 | 11:05 AM
ChillPhatCat's Avatar
Car: '10 Subaru Forester
Engine: 2.5 Boxer
Transmission: 4EAT
Axle/Gears: 4.44
If you have the time and right tools, it shouldn't be too dificult. You may have to lift the engine to pull the tranny out... If you can get one from the junk yard you can pull out the 5th gear from a donar tranny and swap it in, or you could order the part OEM. Once you pull the tranny and open it up you should find the problem, or it should find you... buy a Chiltons or Haynes or Both manuals, they should be able to walk you through it...
1984 Firebird - Daily driver, 305 LG4, T5 - Hurst short shifter, Edelbrock 600 CFM Performer Carb - Edelbrock Pro-Flow air filter, gutted cat, IROC 16x8 Wheels, Goodyear P215/60/R16, AIWA bargain basement (from Sears of course) CD player, Fuzzy dice, Eight-ball shift ****
Check out my ride here $1600!!
First Kill: 2001 Subaru Impreza WRX Wagon (1 person vs me with 2 passengers)
eightsixseven
Dec 16, 2024 01:50 PM
italiano67
Dec 11, 2016 09:21 AM
Camarothatcould
Aug 20, 2015 08:49 AM
drewdock87
South Central
Aug 18, 2015 09:02 PM
mizz0313
Aug 12, 2015 06:45 AM
