speedo cable
Old May 5, 2009 | 10:37 AM
livewire's Avatar
Car: 1983 Z/28
Engine: Edelbrock 355
Axle/Gears: 3.42/Zexel/PBR
speedo cable
Did any Camaro's use a solid single speedo cable? I have an 83 that has the mechanical cruise unit under the hood with the 2 peice speedo cable. the cruise has never worked and I would like to eliminate the mechanical unit to clean up the engine bay a bit. did some later third gens not use this? I would like to get a 1 peice speedo cable. thanks!
Old May 5, 2009 | 10:42 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: speedo cable
Early Camaros, perhaps 82-83, used a transducer which, of course, used two cables. Later Camaros eliminated the transducer. Some Camaros used a two-piece which was joined in the middle; some used a one-piece (that's what's in my 85). I purchased mine from the dealership.
JamesC
Old May 5, 2009 | 11:44 AM
vbMike's Avatar
Car: 1987 Camaro IROC-Z28
Engine: TPI 350ci L98
Transmission: T56 - Hurst Shifter
Axle/Gears: BW - 3.70
Re: speedo cable
My 87 has a two piece cable. Maybe the replacements are one piece.
Old May 5, 2009 | 11:48 AM
JamesC's Avatar
Re: speedo cable
My 85 was an original one piece. I'm not sure if there's rhyme or reason for which of the latter two were installed.
JamesC
Old May 5, 2009 | 11:53 AM
drtask's Avatar
Car: 1988 Camaro RS
Engine: 2.8L V6
Re: speedo cable
my 88 RS had the two piece cable. went picked up a replacement from oreilly's that was a single cable. was kinda confused, but the speedo worked once the new one was put in and FULLY connected (took me a week to figure out why my speedo would intermittently stop working when going over bumps).
Z28/ZR1
Oct 23, 2015 01:04 PM
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
TMZIrocZ350
Oct 7, 2015 12:09 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
rs_z28_vert
Sep 30, 2015 09:47 PM
