TV cable adjusting on a F.I. to carb swap
Old Aug 19, 2001 | 03:23 AM
83CrossfireBomb's Avatar
i put a carb'ed 350 in my 83 Crossfire car. i have hooked up the TV cable but im not sure how to adjust it now. here's the problem i got. i can hook the line to the carb but i dont know where the line is supposed to be at when the throttle is closed. if i pull the line out the cable like it would when the throttle is wide open and let the line go and it will snap back but then i can still push it in about another inch no problem. the car shifts all funny and it used to chirp the tires going into 2nd but now it takes forever to shift and seems to shift too early.
any help is very appritiated
former 305 crossfire fuel injection
350 cubes
hooker headers
750 vac secondary
700r4 with shift kit
Old Aug 19, 2001 | 06:35 AM
Jay 727's Avatar
It sounds like you have a holley 750 vac sec? If so you need to get the linkage adapter for the throttle arm to correct it's geometry, not sure but you probably need a t.v. cable and mounting bracket off a carbed f body or other car, truck or van with a small block and 700R4.
For adjustment I usually start with full cable pull at wide open throttle.
Frozer!!!
Jan 19, 2024 04:55 PM
customblackbird
Aug 15, 2021 10:16 PM
midge54
Jan 29, 2017 07:00 PM
cstrobel65
Aug 15, 2015 10:19 AM
timonator
Aug 13, 2015 11:27 PM
