What flywheel for my T5??
Old Aug 26, 2001 | 10:42 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
I'm swapping a T5 into my 85 IROC. I've got a 2 piece rear-main block.
I went to Advance Autoparts, and they don't sell flywheels.
I went to Big A Auto parts, and he doesn't have specific model listings, only generic listings. This is what he came up with:
Part number ZZ39
14.130 diameter
pitch 12-14
Internal w/o weights.
He made no mention of tooth count or anything else. Does this sound like the right flywheel? If not, where's a good place to get one? He quoted me about $120 for the flywheel. Any help would be appreciated.
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
Custom Thirdgen Subwoofer Enclosures
"I didn't know a bored out Ford could go so slow" -Shenandoah
Old Aug 26, 2001 | 11:46 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
I know you need a 153 tooth flywheel. I'm surprised they're not more common.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
317 RWHP, 418 RWTQ
13.23 @ 107.62 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Member: SoCal F-Bodies
-=ICON Motorsports=-
Old Aug 27, 2001 | 09:29 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
You need the flywheel your car would have come with if it had a T-5, basically. GM still sells one, Centerforce and all the other aftermarket people do too. It's 12¾" diameter, 153 teeth, 10.4" clutch, neutral balanced; you probably want one as light as possible. A 14" 168-tooth one will absolutely not work in a stock BH, so don't waste your time or money trying.
ICON Motorsports
Old Aug 27, 2001 | 02:01 PM
kjgroen's Avatar
Car: Trans Am
Engine: L69
I think i might have one laying around..Kevin
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Vincent135
Sep 28, 2015 10:50 PM
mfp189
Sep 27, 2015 09:25 AM
monte87cortez
Sep 26, 2015 08:10 PM
el_muerte
Sep 16, 2015 12:01 AM
