T56 swap questions
Car: 1991 Trans Am
T56 swap questions
I posted this in the electronics section and got no response so I thought maybe I would get more help here:
Also I will be using this post with any questions I run into with my swap.
In the process of swapping to a t56 and will obviously be using the Dakota Digital box during the swap to work my stock speedometer. However, shortly after swapping the t56 in, I plan on running a megasquirt setup instead of the stock ecm. The MS does not have an input or output for a VSS so I am wondering if I can connect the SGI5 box straight to the speedometer instead? I don't see why this wouldn't work as long as I programmed the box correctly right?
What am I missing here?
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: T56 swap questions
I think you'll need to try the Aftermarket ECM board. I dont know of anyone running a Megasquirt ECM.
Car: 1991 Trans Am
1992 Trans Am
Aug 8, 2015 08:16 PM
