I know burnt fluid means bad tranny....
Old Aug 26, 2001 | 07:10 PM
JETHROIROC's Avatar
When I got the IROC with 33K on it the transmission fluid was brown and smelled bad (almost like gear lube), so I changed it immediately and kept siphoning it out of the dipstick tube about 7-8 times as well. 10K miles later the transmission shifts fine like it always has and the TCC functions. I changed it again (I'm ****) and it appeared normal. There was a lot of the "sludge" in the pan on the 33K change, but no big metal particles or anything. It stunk so bad the whole house smelled like it for days .
My engine is in excellent tune and runs fine except it idles low (500RPM) in drive and sometimes dies in reverse. The car also feels like it's struggling in reverse. It also seems underpowered until it hits about 2500 RPM or so. In neutral it revs up easily and sounds good. I've had the whole top half out of it and been over it with a fine-tooth comb.
So what's the deal with the burnt fluid? I'm thinking the torque converter may be sick, thus my sluggishness at low RPM and excess loading on the engine in D or R, but who knows? Thanks for any insight you may have.
1990 IROC 350
Mods: Too busy trying to make it run right to mod it.
Airfoil, Dynomax cat-back, MSD coil, 180 t-stat, Bald Eagle tires,
Hypertech fan switch, Accel 23# injectors, Holley AFPR, ported plenum,
Ported Daytona Yellow stock base, Moroso valve covers, other stuff,
Ruger P95DC, hot wife, new oil filter, thick rubber floormats, no cats.
18.0 @ 85MPH since I'm one big-a$$ MF
"It's better to have and not need than to need and not have."
Old Aug 27, 2001 | 07:17 PM
JETHROIROC's Avatar
BTT
Old Aug 27, 2001 | 10:47 PM
breathment's Avatar
mines burnt too, but im not having problems other then the TC quickly locking and unlocking while decelerating in OD or D. but other then that i think i just need to install a Tranny cooler. cause the tranny was rebuilt less then 2 years ago.
88' GTA 350 MODS---> air foil, K&N, Shift Kit, 180* therm, TB bypass, Gutted CAT
Old Aug 27, 2001 | 10:50 PM
colincamaro's Avatar
go to a jiffy lube or quik lube place where they can purge your trans and get ALL the old fluid out, worked wonders for me!
89 RS 305 TBI/Hooker catback
Old Aug 29, 2001 | 01:10 AM
Mo's Avatar
Mo
My tach reads about 500 at idle as well, but I hooked it up to my computer the other day and was really idleing at 750-800...
90 IROC 5.7l (L98)
ram air, K&N's, air foil, full exhaust
LIKE A ROC
http://members.nbci.com/IrocZgarage/home.htm
Glowsock
Jul 24, 2025 03:15 PM
maroe624
Apr 16, 2017 08:29 AM
backtothe80s
Sep 5, 2015 12:39 AM
dibella989
Sep 1, 2015 04:12 PM
someone972
Aug 30, 2015 12:52 AM
