camaro rear end
Old May 24, 2009 | 08:39 PM
96camaross's Avatar
Car: 1996 chevy camaro ss
camaro rear end
what size ring gear came in the 93 and 94 camaros was it the 7.5 or the 8.5
Old May 24, 2009 | 09:04 PM
big gear head's Avatar
Re: camaro rear end
7 5/8 with 28 spline axles. No Camaro had the corporate 8.5 after '81.
Old May 28, 2009 | 12:36 PM
TKOPerformance's Avatar
Car: '86 Camaro, '02 WRX, '87 K5, '67
Engine: 350 TPI, 2.0turbo, 383 in the works, 289-4BBL, 232, A-head 4-cylinder
Transmission: T56, 5-speed, 700R4, C4, T176, semi-auto 2-speed
Axle/Gears: 3.73, 3.90, 4.88, 3.55, 3.54, 7.00
Re: camaro rear end
Yup, 7.625", which is the same as a 7.5" just with a 1/8" larger ring gear. Parts interchange though, and when doing gears in a 7.5 you just install 7.625" gears as that is what is currently available from the aftermarket. The 8.5" 10 bolt was only found in 1/2 ton trucks in the later years. I am a fan of the 8.5. I built the 8.5s in both ends of my '87 K5 and they are stout, yet much lighter than a Dana 60 or GM 14 bolt. The rear uses full floating axels built by Warn, a Detroit Locker, 4.88 gears, and a TA girdle. The front uses 4340 Superior axel shafts with 76x u-joints, an ARB air locker, 4.88 gears, and studs in the caps. We'll see how they hold up to the new 383 and 38.5" Boggers, but I think they'll be fine.
hectre13
Dec 11, 2023 08:14 AM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
BlackBoulder
Aug 11, 2015 11:15 PM
