flywheel help
Old May 25, 2009 | 07:50 AM
camaro8tysvn's Avatar
Car: 87 camaro
Engine: 355ci
Transmission: richmond 5 speed
flywheel help
i have been working on a 86 trans am that i bought cheap for a parts car with a bad 305 carbed motor and a richmond 5 speed. and the car grew on me so im fixing it up. it had a t5 stock and it has that bellhousing with an adapter plate. and the stock flywheel. i know 87 1 peice rear main seal flywheels are different but i dont know about 86 so do i need a new flywheel. im putting a late 70s 350 in it
Old May 25, 2009 | 10:59 AM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: flywheel help
if you are using a 70's block, its a 2 pc rear main seal, so you need a flywheel for a 2 pc setup
Old May 25, 2009 | 03:07 PM
Car: 87 camaro
Engine: 355ci
Re: flywheel help
ya but im trying to figure out what the one i have is the one from a 86 305 is
Old May 25, 2009 | 03:45 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Re: flywheel help
everything i have tells me that 86 and up blocks were 1 pc rear main.
so as long as the block is an 86, it should be 1 pc.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Vincent135
Sep 28, 2015 10:50 PM
mfp189
Sep 27, 2015 09:25 AM
monte87cortez
Sep 26, 2015 08:10 PM
el_muerte
Sep 16, 2015 12:01 AM
