super t-10
Old May 28, 2009 | 08:55 AM
kowalzekc's Avatar
super t-10
Can anyone tell me if the t-10 tranny that came in the earlier third gens is stronger then say a t-5 r t-56. I was just wondering for my own curiosity. Thank you
Old May 28, 2009 | 10:14 AM
TKOPerformance's Avatar
Car: '86 Camaro, '02 WRX, '87 K5, '67
Engine: 350 TPI, 2.0turbo, 383 in the works, 289-4BBL, 232, A-head 4-cylinder
Transmission: T56, 5-speed, 700R4, C4, T176, semi-auto 2-speed
Axle/Gears: 3.73, 3.90, 4.88, 3.55, 3.54, 7.00
Re: super t-10
Stronger than a T5? Yes. Stronger than a T56? Doubt it. The Super T-10 is an aluminum cased 4 speed that GM started using in the early 70s as a replacement for the M20, M21, and M22 Muncie 4 speeds. The Super T10 is a tough 4 speed, but it lacks overdrive, which is why GM eventually switched over to the T5 and then later the T56.
Liberty and other can build a Super T10 to live behind serious power. I know a guy who runs one in an early Nova that runs in the high 10s with no breakage problems.
Old May 30, 2009 | 06:31 PM
5.0slayer's Avatar
Car: 91 camaro RS
Engine: 350, forged 355 in the works
Transmission: 4 speed goin to th400
Axle/Gears: stock 9bolt, 3.27
Re: super t-10
ive got a full 4 speed conversion for sele if any one is lookin for one, its every thing you will need to put it in, and use hydrolic clutch too, only thing you need is the mount
Old Jun 15, 2009 | 09:05 PM
Z51vett's Avatar
Re: super t-10
how does the super t-10 clear the torque arm? Looks like the linkage and shifter will not clear the torque arm mount, at least if you run the heim joint linkages
no green
Jan 9, 2016 09:22 PM
AmpleUnicorn88
South West Region
Dec 11, 2015 11:53 PM
Zell1luk
Sep 29, 2015 10:36 AM
Damon
Sep 26, 2015 04:29 PM
Dragonsys
Sep 25, 2015 03:51 PM
