electric fuel pump or not
Car: 87 IROC Z "ZZ4"
Engine: 350 "ZZ4"
Transmission: ck performance th400 3000 stall
Axle/Gears: 3:73 10 bolt
i am currently doing an engine swap in my camaro i am replacing the 305 tpi(motor is no good) for a carb motor now the motor i am installing has a mechanical fuel pump and the car has a electric pump can i use the electric pump instead of the mechanical also i see the two fuel lines on the driver side how would i hook that up??
thanks
thanks
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
